Well Fellas,
Leave it up to me to do something just plain STUPID. . .
It was cool and sunny when I got off work so I decided I would do some work on my Yak. The only thing I managed to do is cause real damage to the right wing that is going to be a real Pain In The A__ to fix. Let me start with picture #1.
Yes, that is one of the aileron servos going through the edge of the wing sheeting. No big deal right? The more observant of you Fellas, like
@Snoopy1, will notice it's a bit worse than it first appears because the damage doesn't stop there. Let's continue with picture #2.
YIKES, what stool knob took that picture? As bad as the picture is, you can see the servo didn't just go through the wing sheeting, it also went through both of the plywood servo mounting rails. As you see in the picture (maybe), the lower plywood servo rail is broken in half. In case you're wondering, it does get worse. . . . .
It broke the top servo mounting rail out completely. So now I have to cut the wing open to see what it's going to take to fix this mess. To say I'm unhappy is an understatement. The ironic thing is that this happened on the third aileron servo and the first two went in without any problem whatsoever. Obviously, any chance of wrapping this plane up fairly quickly and flying it just got flushed down the toilet. . . . .
