Some info on laser cutting. I have done quite a bit of CAD drawings, and I learned here and there a few things. When you draw something, for example a slot for stock balsa, you always compensate for the laser. It is just like your circular saw or band saw. You never cut on your line but a little bit over, otherwise your part is not the right size. Same goes with the laser. As for making other scale kits, I simply can not redraw every size kit people are requesting. As for now I have drawn a 100" wingspan, as this was the original size we planned to have, but then went to 86.5" wingspan. All slots and notches for the two sizes are made for standard stock balsa. Going smaller then 86.5 or larger than 100" will obviously have bigger or smaller slots. However they would be so minimal that an experience builder will have no trouble to go about it. Also, I will only have cowl, canopy and wheel pants for 100" wingspan available, in case somebody is interested.
