next step, you need to check and make sure that the slots, especially on the bottom cowl unit, is length wise, at least the length of the long part of the tab.
I used the dremel router to make sure that the hole was slightly longer on the forward side of the slot.
before i continue, i want to explain some rationale. you want the tabs to be on the top cowl piece. that way, when you remove the top cowl for working on the engine, baffles, whatever have you, you do not want these things sticking up and getting in the way.
when the tabs are placed on the top cowl, they have to open to the back, so that it will capture the bottom cowl as you slide it back.
ok, back on track here, the router opens the slots on the bottom cowl segment, here is where it is important not to bind as you put the cowl on and off. but the back aspect of the slot should be kept at the measurement as it was.
