Ohio AV8TOR
Just Do It
orthobird said
yes!! i was at cowtown! were you there also?
Ah so you are Cam and you won Rookie of the Year, congrats by the way.  I work with Rex (Capt.Roll).  Sorry I did not know in to introduce myself.  Next time
IMAC-FANATIC said
So Doc, how did you do at the event, place doesnt matter, just hope ya had fun and flew well.
it was a ton of fun, and most importantly, i learned from my peers!! i am trying to soak as much in as i can, being that i want to be a better pilot.  there were i believe 9 pilots in Basic.
the build is back on!
did a little bit more this morning and this evening.
want to show the balsa stock, that is 1/2" thick, that we have to use as the trailing edge and for the hinge line.  this balsa length is about 20 inches or so, and for one wing, you have to place 2 and 1/2 stacked together.  what i did, is i made an angled joint, to increase the surface area for the glue.
ohio, what is your name? did you compete while we were there? thank you for the compliment!!
i also marked the right and left wing and the top position on the root side of the wings and also on the wing chucks.
i have glued the servo boxes together.  i am also attaching photos of the tools i use to cut thru the foam.  not pictured is my 5 foot long brass tube for the servo wires. i will be using two servos per aileron, and one servo will be near root, and the other one will be mid wing area.  not at the tip.
got some more work done.  i have glued the LE and TE for the wings.  have sanded them down some.  still need to finish that part.
i started working on the root caps.  this part takes a bit of planning.  i want to use a anti-rotation dowel on each wing (x2), and then use the DA studs .  i will work on making the hard points on the root side of the wing.
the root caps also are a bit short, so i am augmenting them.
just glued on the hard points for the studs/ dowel on both wings, and the left wing root cap is glued on, waiting for it to cure.  once that one is done, then i can glue the right wing root cap. then sand time for the root cap and LE and TE. then, set the incidence. then cut out the aielerons, then add LE and TE to hinge gap. then servo boxes!!  etc...
still long way to go.
have yet to hear from Henry Piorun regarding the shroud.  i better email him,.
