IMAC Delro Raven 3.1M build
Wacobipe
@MattyMatt ...is there any thermal barrier between your canister mufflers and the electronics in the fuse? It does not appear so from the pictures but not entirely clear. I'm contemplating the need in my 2.5m Raven. Thanks.
Allan
30cc
Very nice. I will get some pics up of mine soon. in primer just final finishing before paint. does anybody have any details of where / who may do a paint mask for the raven. I really don't fancy masking that up myself. or does anybody have the vectors so I could get a mask cut myself.
Cheers
Jlc
Cheers
Allan can't wait to see your progress. Delro sells the Raven outline. I ordered it along with some other stuff my kit was missing.
Wacobipe
Whoa...Delro sells it? I had no idea...and that makes life IMMENSELY easier knowing that!!! Thanks Jlc!
Jlc
I hope I'm not leading you a stray. I haven't received my stuff yet, actually it might be awhile but as I understand it they are sending my the outline of the raven cut in my scheme color.
Jlc
Ok I had to back up and do the cowl before I set the firewall to make sure I didn't block access to where I needed to get. Delro uses aluminum tubes blind nuts on the front and tabs on the back. I got lucky and fit is perfect. I opened up the hole in the back of the cowl but haven't opened the hole in front for the carb yet. I ordered nylon cap screws to replace the flat head screws.
