From the manual: (the next step for me)
2. Drill Four #8 Holes in the Landing Gear Pilot holes in the L.G. Mount. Use a drill press. Mark and
drill through the L.G. Mount and ½” by ½” Hardwood with a #8 tap drill. Tap for 8-32 x 4 Socket Head Cap Screws. Nuts are not required.
this is what I did (so far):
used a ruler and a angle to determine where the landing gear needs to go, and then did measurements til i fugured out what was square.
i then marked where I thought, the holes would be or should be:
here it is, after drilling and tapping, and I am satisfied with this, however......
You can probably read my mind. I am itching to put an aluminum angle in there, with a aircraft quality plywood and blind nuts to finish it off. Just do not trust leaving that alone, but I am crazy like that....
