Ok I'll check everything. I know in high rates, the elevator servos sing pretty good. I might be too tight on the bevel. Other than full deflection in high rates, the servos are almost dead quiet. Some investigation is in order.
Since the power safe uses two battery's, I should measure watts with only one battery in place, then check the load on the other lead to make sure it's the same?
