Extreme Flight 88" Edge -- now with EXP sized horizontal stabs
Artp47
Picking up a yellow blue edge 540 tomorrow.. GP 61 with plane bender smooth pipe can't wait.
Thanks for all the info in this thread
Artp47
Big question in my mind do I use the stock muffler and keep it light, or plane bender pipe and go for the extra power.
3dbandit
I would go with the stock muffler. lighter planes typically fly better. When you add the weight of a pipe, regardless of the power benefit, you can't over come the higher wing load when trying to 3d.
I avoid can's/pipes at all cost. Extra weight, extra cost, extra hassle.
3dbandit
I would stick with the stock muffler. If you feel you want to fly faster, at the cost of wing-load, then I would go for the pipe.
Odd's are, you will be more than satisfied with the power...
Artp47
thanks for the options[/QUOTE]
Registered User
http://www.GiantScaleNews.com/forums/customavatars/avatar41926_1.gif
Joined Jul 2009
Checking the CG on my edge manual says 6.25 to 7 inches at the wing root, that puts the CG behind the wing tube. Where did your CG end up ?
Thank for your help
