Willfly4money
Finally finished my EF 91" yak with the GP 61 with MTW header stock length and proflow can rear exit, flew it today with xion 24x10 and after playing around with the high end I ended up with around 1 and 3/4 or slightly more on the high end and 6700 on the ground, she gets pretty warm at anything under that setting. I haven't messed with the low end yet. My header broke at the flex joint after a few flights (it was a used header) but I havent found a good method to mount the can yet as there is not alot of room... With no mounts the can is actually wedged in the tunnel fairly tight, though I should have put a support around the front of the can near the rear of the motor box. The proflow can just barely fits in the tunnel with no room to put a mount as far as I can tell. I bought a carbon mount from VVRC and it just won't fit, any suggestions?
