3dmike
How about $85? =D
Wow I've not seen that happen often! Nice job Kole!
How about $85? =D
How is the vibration? A guy at our field had one on a 3DHS yak 55M. He said it was vibrating so bad the plane was coming apart SFGS, spinner bolt etc. Vess 23B.
@ limitless Aero
Why would you think it would be the carb Screen, when the problem happens when the cowl is put on, just wondering, the only thing i have done different since the Flights at the Sod farm, was change the fuel line and had to route it a little different, where before hand it. came out of the tank looped it around the tank once and then threw bottom of motor box to go around a servo, and then to the carb, that was the last line set up the new line set up goes out of the tank over top of the throttle servo, along the left side of the motor box and to the carb basicly a striaght shot to the carb besides one small turn,,, I also checked the choke and it is going full choke,, i did also notice today that when it was choked and you started it with the starter, it would just start and run with the choke on, it wouldnt just pop
