Nope, just fiberglass and they can chip or fail pretty much any time. Also if anything gets sucked in and doesn't allow the reed to lay flat it could prevent the vacuum necessary to draw fuel correctly.
Ok checked reeds nothing seemed to be under them checked diaphragm it looked good removed needles and checked them all good carb screen was clean, the carb bolts did seem a half a turn loose so I hope that was the problem bout to put it back to get or and go from there
