Gp-61
With all the changing around, you could be accidentally introducing a new problem each time. Recommend you not change anything else when troubleshooting until you find the issue
KoleDeRacer
1000cc
It probably is the carb, sounds like you have been really thorough with your troubleshooting. There are more bad walbro then you would think. I will get a new one to you.
Yowzilla
100% sure you have a fully closed choke? I see some crunched wood on your linkage. I had a time with starting until I discovered that my fire wall was ever so slightly keeping the coke plate open. The way I found out was pushing the choke plate by hand and it was springing back open a few degrees. After I cut relief in my fire wall it pulls fuel well.
Now I prime with 7 pumps of the prop with choke on and throttle full open. Bring throttle down to 15% and on first or second flip it will pop. Close choke and flip. It starts on the second or third flip every time. Well the last 8 times.
3dNater
My impression was thst the fuel drawing and starting issue was solved and now we are trying to troubleshoot tuning problems. Is that right?
