2robinhood;19781 wrote: Hanging on the wing tube with almost 3/4 of a tank of fuel = 34.0 pounds.
Each wing = 4.1 pounds.
34.0 + 4.1 + 4.1 = 42.3 pounds with 3/4 of a tank on board.
So I was only off by a pound or so................:uncomfortableness::uncomfortableness::uncomfortableness::uncomfortableness::ambivalence::ambivalence::ambivalence::ambivalence::uncomfortableness::uncomfortableness::uncomfortableness::uncomfortableness:
My Edge has smoke and pipes and she weights a tad over 43 pounds.
jamesrxx951;19784 wrote: Mine is just a tad over 40LBS. Running a DA 170 with RE3's, Mej spinner that is only a few ounces, 9 servos, 2 Pulse 5000 MAH lipos for receiver and 1 2600MAH Fromeco Li-ion for ignition power. Single JR power buss receiver and a Dubro 60oz (I think that is correct) fuel tank. No effort to reduce weight at all. Love the way it fly's.
Wow..this helps a "LOT". Thanks guys. As I mentioned, my 260 is 41 lbs., 14 ounces. I am "VERY" pleased how she flies. Punch out from hover is incredible and I have trouble sometimes getting her down because she floats oh so nicely. Well, not really trouble. Just have to keep reminding myself to come off the gas pedal on my down wind leg and coast her all the way around. Here is what I came up with on the Sukhoi. 8.12 main wings with four servos, 2.05 stabs with four servos, 15.7 fuse. (Also chose to go with a 60 ounce Dubro) Don't know if it will really need it or not, but if it proves to be un-necessary, I can always change that. Motor, prop, spinner, exhaust and batteries yet to be installed. Uninstalled parts, I figure to be about 15 lbs. All up less any fuel, I am expecting 41.8 lbs. I figure that since the 260 has just a smidgen less wing area and stab area as well, The Sukhoi about a foot longer... coming in 6 ounces lighter, it should be juuuust fine. Especially since yours are right in that same range and they are floatin' fools. Whew, I feel much better now. Thank you so much for taking the time to get the weights and such for me. I do appreciate it.
