Luchnia
Nicely done and .5 lb lighter than mine so should be a blast to fly.Fully assembled, dry weight = 8.5 lbs. Ran the engine tonight, started right up after I got the fuel in the pump. Have some things to double check, tighten up, and adjust. Then schedule a maiden. May be a bit before I get there, but we'll see. The tach is only temporary sitting on the fuse. Will pull it off before flying.
