Hi Smitty and rmeyers - did you install the rudder servo like shown on page 14 or page 15? One shows the servo spline to the rear and the other shows the servo spline to the front. Not sure if it matters, I have mine like it is shown on page 15.
Does your pull-pull cable rub on the leading side of the exit inside the fuselage? I though mine was fine until I looked inside and down into the fuselage. I am using the suggested rudder servo arm and the rudder servo control horn measurements., I even tried crossing the cables but that didn't change the rubbing.
Is the cable rubbing on the fuselage acceptable for flying? I think not and maybe the rubbing will cut into the fuselage or fray the cable?
I will hate having to lengthen the exit slot but think it is my only choice. Now I'll need some exit hole trim covers, I saw some nice ones that looked like they were made of metal with simulated rivets. I will paint them white. Anyone know of some exit guide covers that are 2 inches long? The photos on the PAU show the Sukhoi with the ones I'm am seeking.
Hope these are going to be long enough -
www.aircraftinternational.com
