i used longer bolts and put a locknut on the back with my Pitts ChallengerI noticed on the pushrod connectors that just screw in to the control horn with no lock nut of any kind. Do you guys just use loctite on them or do you replace them with longer screws and put locknuts on the backside. I sure like the locknut for that double security.---Smitty
I am going to ask a dumb question. What is the advantage of using a offset rudder arm, I don't see where it let you get more throw out of the arm.---Smitty
Going to work on the Sukhoi today. Will be opening all the holes in the covering and opening the servo mounting holes. Love the idea of a hole punch in masking tape for hinging. Will go get one and some more wax paper.---Smitty
I borrowed the hole punch idea as well. Worked great using a cheap single hole punch and Scotch Blue masking tape. Epoxy on one side Gorilla glue on the other. Watch the hinges I found there to be a mix of genuine Robart and Chobart junk. I replaced every questionable hinge point with Robart Super Hinge Points.
