TonyHallo
Kind of loss steam on this project over the holiday season. I have the rudder pull-pull completed and have a plan for the elevator control. The next step will be the wing lift struts, with all the talk about lathes and small parts decided to make the wing lift strut forks. The full scale are 1/2" threads so a number 8-32 will be about the correct 1/3 scale size.
I made a power feed for the mill/drill out of wiper motor. Need to mill four flats on the round bar for indexing the stock so this will be good test for the feed.
The flat milling went well and the stock was chucked up in the four jaw chuck on the flats and turned to the largest diameter of the fork.
Back to the mill and put the flats on the fork for the trough bolt.
I used a Dremel abrasive wheel to slit the end. It took three wheels to get the job done. The arbor is made from 1/2" stock as my cheap arbor bent on the second pass.
The through hole was next, drilled and tapped for 4-40. A set screw was installed to keep the forks rigid during finial turning.
Back to the lathe for finial turning.
The 8-32 threads were put on with a die nut.
