Real Flight 7.5...
Just a little fun tonight...
Xpress
Some of you probably know this, but some probably don't. The Yak 54 that Terryscustom edited needs to have the GSN Scheme imported into the sim in order for the color scheme to work.
There are 2 separate files:
-Extreme Flight Yak 54 104 -- This is the aircraft. It will come with the Yellow EF scheme as default.
-GSN Yak 54 -- This is the GSN color scheme that will need to be imported separately in order to view it.
Once you import the GSN color scheme you will be able to use it with ANY of the stock Real Flight 7.5 Yak 54 models (Russian Thunder excluded).
Bartman
Defender of the Noob!
Xpress, I'll send both files as a .zip file
i'm sorry if i haven't done it already, been soaking up the holiday cheer! (burp)
ericb
Team WTFO
Thanks for all the work you guys put into making these planes better. I really appreciate it.
