You guys are too good for me!
Hell no! Everyone's welcome. Server crashed so I started my own. I'll leave it up for a while.
I will get it to you once I get the required files figured out
Hey everyone,
I am having some trouble sending my schemes to people. Can anyone tell me what files need to be included when sharing custom schemes?
Thank you @Xpress! It worked like a charm!You need to export your color scheme from the sim into its own CS format. Should be under the Simulator tab at the top left, then go to Export.
From there, it should export into one of the folders inside the Real Flight folder, of which you can send to people. It should have the tag "CS" at the end.
I will get it to you once I get the required files figured out![]()
Hey Mark... now that you have it figured out, care to share that scheme again? It didn't work first time around. Thanks.....Thank you @Xpress! It worked like a charm!
Will send it to you shortly!Hey Mark... now that you have it figured out, care to share that scheme again? It didn't work first time around. Thanks.....
