3dmike
This is one cool switch. It offers complete dual battery balancing and redundancy with an ultra-small footprint. The new intelligent redundant battery balancing switch also works as a safety that prevents the connected components from receiving power until the pin flag is removed.
This switch works with any single or dual battery system and is compatible with battery voltage range from 2.5v to 28v. It comes with a Pin Flag and Ultra Bright Blue LED which can be mounted discretely on your scale model. The Pin Flag controls the internally mounted switch and battery redundancy circuit. The result - beautiful scale appearance with dual battery redundancy peace of mind.
This new balancing technology offers battery balancing with zero voltage drop and redundancy which means it can handle huge loads without generating heat. This also means your receiver and servos get all the power unlike conventional battery balancing which loses precious power as heat.
Price: $41.45
Link: http://www.redwingrc.com/index.php?main_page=product_info&cPath=3_7&products_id=488
Details:
Package Includes:
-1 x Pin Flag switch with mounting hardware.
-1 x Ultra Bright Blue LED with mounting hardware.
-1 x Dual Battery Balancing power switch circuit.
-2 x sets of Input and Output connectors of your choice.
Specs:
-Ultra low footprint for the best scale looks.
-Works with single or dual battery configuration.
-Works with all battery chemistries. LiFe. LiPo, Lion, NiMh, NiCD. Battery voltage range can be from 2.5volts to 28 volts.
-Capable of handling input voltages up to 28volts.
-Minimal external footprint - All you see on the outside of your model is a 3mm Pin Flag socket and (if required) an ultra-high bright Blue LED. The Pin Flag controls the internal power switch and dual battery redundancy.
More pics!
Price: $41.45
Details:
Package Includes:
Specs:
More pics!
