TonyHallo
Another trying day at the field with the One Design. Checked voltage coming out of the IBEC, 5.4 volts open circuit, decided to measure the loaded voltage, 1.5 volts. I bought a spare with me, tested it open circuit, 5.9 volt was the lowest setting I found by moving the jumpers. Started engine, started easy but left cylinder was dead, new plug, still dead, swapped plug wires, still dead. I brought the ignition module off the crashed Cherokee engine with me, swapped it out but the timing was too far advanced. Went back home and took the magnet off the Cherokee engine, back to the field, timing was off, threw the towel in.
I did fly my friend's 100cc AJ Slick, what a great flying plane. He just got done putting in a new Power Box Mercury SRS in it. Last time it was flown my friend handed me the transmitter after he flew it. I taxi to middle of the runway and lost all control, my friend ran out and grabbed the plane, the power lights were lit on the old Mercury but there was no control, he sent that box back to Power Box USA for evaluation, I think he said the repairs would be $60 if they didn't have to send it back to Germany. I flew the plane first on my second flight, my friend took over after I landed and flew for several minutes, the left wheel fell off on landing and that ended our day.
When I gone home I sorted out the timing on the engine and plan to try again tomorrow. The original ignition module was set at 5 BTDC, I swapped parts around and now have the replacement set at 3 BTDC, close enough. Hopefully the left cylinder will light!.
