Here is that plate I made, to glue it all together, so you do not have to worry, years from now, about changing out the tail wheel spring, and then the blind nuts pop off. It would then become a real PITA to put them back in there. Possible, but more difficult.
Additionally, this airplane, with a 200 upfront, will have a tendency to be nose heavy. SO i would not core out any of the tail foam. If you are using a 150 with stock muffs, then go for it. Even a 170, go for making tail as light as possible.
here is the plate, this will be glued in from the inside of the fuselage. The purpose of this is to cover the blind nuts, so they cannot pop off.
I have countersunk the wood, so there is full contact of the ply around to adhere to.
here are the exposed blind nuts:
currently, it is being glued in. When I get home from work, I will take the clamps off, and show what it looks like.
