Before I take a Saturday afternoon old man nap, I thought I would share some exciting news. First the photos of the nearly finished up baby Yak. Got the throttle servo in and programmed. Also got the choke pull rod engineered for perfect operation. Cleaned up the inside of the fuse. That wiring was driving me nuts. I also got the newly retreaded White Rose wheels mounted on the landing gear and installed on the fuse. I am just about almost finished. About all that is left now is to put the top motor box cover on, cut the bottom of the cowl for the Jtec Pitts muffler...(yes, I decided to go with it.) and lastly, build a baffle in the front of the cowl.
Now for the exciting news. As mentioned, I decided to try a variety of different exhaust systems....but stalled at the Jtec Pitts. After going through the BE 62 it ran pretty ok. But just not what I felt it was capable of. I really felt it's potential was still out there. So of course going through the ignition system and timing it like I do my "dubs", bolted on the Falcon CF 24x9. Then bolting the Pitts muffler on instead of the stock exhaust....I fired her up. It took quite a bit to get her going. Bone dry from being apart. But once she got fuel, she fired right up. And Ho ho holy cow was I surprised. I was told that maybe I should try a 23x8 to 24x6 to start with. Yean, not so much. (Not enough prop for this little beasty) A few days ago I tried the Mejzlik 24x10 and got just over 6300. That was before I went through the ignition system. First run with the Falcon 24x9, she topped out at 6710 on the rpm.
I let her cool down for a few minutes....(It's about 40 degrees outside right now) After I was satisfied that the engine had cooled down enough, I reached over and flipped the prop twice with no choke....and "vrrroooooom" to life. Cleared her throat a tad and topped her out. 6720!
She is already gaining and has not even left the ground yet. I am very impressed and quite pleased already. The throttle transition is glass smooth and lightening fast. Zero...(yes, zero) midrange burble. I am going to static thrust test her maybe tomorrow. I am anxious to see what she is pulling. At 19ish pounds and 95" wingspan...this baby Yak is shaping up to run with the big dogs. Heck, I am not so sure any of my 3w's run any better.
Something else...I love my big planes. And I will probably never give them up. But I am really starting to understand why these 90" plus wing span planes are so cool. Light, easy to work on. I will post some assembled photos soon.
