Fibertech
Just a short note on our e-mail. It will be down for a short time as we are changing servers and having a small problem. Please PM if needed.
Rick
ericb
Team WTFO
Getting the hinging done. One other benefit of the split ailerons is it is very easy to hinge an aileron. The most hinges I had to worry about at once was 6.
ericb
Team WTFO
I used to hinge with the ailerons taped straight, but Terry showed me this method and it is much better. The straight way I had a hinge that was off center a little bit and ended up binding. This way they are all lined up perfectly and won't move.
I used to hinge with the ailerons taped straight, but Terry showed me this method and it is much better. The straight way I had a hinge that was off center a little bit and ended up binding. This way they are all lined up perfectly and won't move.[/QUOT
That is a great tip!
ericb
Team WTFO
Just on more benefit of living close to Terry. I can stop by while he is building and learn so much just by watching.
