I changed my tail wheel also, it had the tail sitting too low for harrier landings. My buddy had a tail wheel from a hanger 9 extra laying around that I used. Simple setup, Aluminum bracket, bent music wire and a nice fat 1" wheel. didn't change the cg at all.
I've got 9 flights total on mine, CG is on the money, perfectly neutral, all trimmed out for hands off upright and inverted, knife edge mixes all set ( not much in the way of mixes, only needed to add aileron to left rudder knife edge, right rudder just needed a little elevator)
I seem to have a small , I guess, "flat spot" in my throttle. It seems that between zero and 1/4 throttle there is very little response. My throttle calibration was done correctly, I tried increasing the timing, helped a little but it's still there. Would adjusting the frequency of the esc help this ? ( sunnysky 2820-950, ZTW "a" series 50 amp esc )
I also tried going to a 13X6.5 from a 14X7, slowed the flight speed down a little but didn't really make a change to the problem .
BTW added new pics of the 55" yak ( first color scheme) to that thread
I use an " idle up" on my air planes, and that helps with the punch the from low end. I basically set a switch to the trottle, and use it to keep the prop spinning at a low rpm when flying.
This cuts out the time the ESC spends trying to get back in sync with the motor.
