Hi Tony not trying to highjack the thread but would like to ask you a question about Gyros. First do you use them if you do which ones have you used. I am getting a little older and it seems to be getting windier every year. It is stopping me from going flying at times and would like to buy a good gyro for a few of my planes. I have couple of gyros but have not found what I am looking for. The Aura is difficult to make work difficult to program and does not work constantly, have cortex the older one it’s ok but does not really do much, have one of the original power box gyros and it has been been the best so far but it must at least 15 years old. I believe that that ones that are available today are much better the one I keep looking at is the SF10 pro from Booma. Interested in your thoughts. Thanks.
I have experience with three different gyros, of course none of ones you mentioned. My first experience was with an E flight M12 foamy, my first and only foamy so far. I bought the plane to fly at the local boat launch parking lot. I felt like it was always fighting me. It was Spektrim AX3S or something like that, it came preprogramed with the plane. Didn't like it at all.
My second experience is with the Eagletree Guardian. I had one in my quarter scale Cherokee, put it in to play with and found it to be rather nice, the plane flew the same with or without it it was just less work with it on. Sometimes I would just to to land using throttle only, get the plane lined up and ease it in by controlling the throttle only. You need a laptop to tune it. After flying in the NASA Fall Classic with 7MPH cross wind on three days I decided to put one in the Champ. The company is gone so I had to find the program online off another user. I only put a half dozen flights on it after the install. Below are two telemetry logs before and after the installation, I made the logs the same time length about 13 minutes, the top one was during the contest. I apparently landed midway during the second flight and took off again. Which one looks like less work? I found two Guardian online and purchased those.
My third experience is with a FrSky stabilized receive and the last Cherokee and that didn't go well so I will no use any of those again, just purchased an RB30+ redundancy bus for the Cherokee and the first i did was disable the stabilizer. Do know if all stabilized receiver are the same but in FrSky case the stabilization is rate only, on head holding, at least that's what I read.
Spoke with a very good local flyer here that uses the Barvian Cortex and likes it, he stated he uses 20% gain for what it's worth. When I found he uses one I didn't feel so bad using one either!
I do plan to install a Guardian in this Cherokee build.
View attachment 123752View attachment 123753
Thanks for that I appreciated the reply.
Closing in on the seat construction. I hope to mount the radio gear and batteries under the back seats. In order to access the batteries, need the front seats to tilt forward. Rather than fill the seats with foam, added 1/4" plywood hard points to attach the 1/16" thick G10 hinges. Also reduced the thickness of the front seat by 5/16". The red peel ply spray paint should be here today, hoping to test the color and finish.
Thank you both.
The red peel ply arrived, needs a little texture. Ordered a can of Rustoleum texture paint, going to try this as a base.
