		Thanks, do you think it will still be fine at 5000' altitude, it seems we lose a lot of power here in CO.
Good point about density altitude... Yes you will not see the same level of performance as an aircraft at sea level for two reasons:
1- air - the airplane will not see as much oxygen for combustion, and this produce a little less power.
2- prop - the prop will not "bite" as much air (as it isn't there) resulting in less performance.
You'll need to adjust your engine choice accordingly.
