Extreme Flight 76/83" MXS
3dNater
3DRCF Regional Ambassador
Tom I am not an expert on this but I'll take a stab at it. Anyone that knows better feel free to chime in.
My understanding is that you need at least twice as much room for air to escape as what is coming in the front of the cowl for proper engine cooling. You can cut it all out of the cowl, or you could cut some out of the fuse if you are leaving the canister tunnel open. Lots of guys like to cut it all out of the cowl so they aren't putting air pressure on the inside of the covering and canopy.
I have seen some cool different options... like cutting diagonal slots so there are multiple exit holes like a grill. You can get creative to make it look good.
AKfreak
There is a boxed tunnel that runs a good length of the fuse. It's boxed off so no air can get in the fuse. I think I will make a plate there and use the diagonal crosses. Basislly all I need to do is measure the two round cowl opening, and double the surface area as an exit. That seems simple enough.
Ohio AV8TOR
Just Do It
AK here is the bottom of my plane. If you do the math on the 3 inlets you will see that more is needed than just that lower cowl opening. I am going to wait until my VVRC40 is brok in and I have made this cover that I might put on over.
AKfreak
That cover is BA. Nice job! What did you make it out of, is that balsa sheeting with covering? That motor fits so much more nicely.
