IMAC Scratch build Laser 200
The control horn widens out at the top to except the ball link. The square plate below with the four holes that screws to the elevator it looks like it will difficult to get a screwdriver straight down onto the screw to screw it down because the top part that is so wide.
wow you have a good eye, yes indeed it was a bit of a problem but doable, using 2-56 screws , I should use allen heads with a ball.
landing gear in the flight system will be accessible from the bottom because the Batteries on top
So if I understand you correctly the black part is also printed. Is it soft like a tire.
Yes it is , using TPU filament, which is basically Urathane , the amount of flex will depend on the amount of fill I program into it.
Wow that is interesting, looks good how much does it weigh or is it comparable to a H9 wheel the same size.
Today, another first for me, for the turtle deck, same principle as I have done before for the wings, In the picture a fellow modeler came over to help me with the cutter, here just holding to show
