Sport Dalotel Junior
IMAC FANATIC
40% happier than most folks.
Wow, just wow. That's awesome. I've talked about that and wondered how sick it would be to fly an IMAC sequence in fpv with a single stick control, be the only way "realistically' and monetarily to fly a sequence in a aerobatic plane for me and most people.
Sir, I applaud your efforts.
Thank you, they will be available sometimes in 2015 directly from Aloft Hobbies.
I will post pictures of the fully working radio once we have it,
I have been flying my own design for a while now using the same electronics and it is bullet proof
inside of wing panel just about done and then sheet it
landing block since no retracts on this one, servo plywood installed
and paper tube inside for guiding the wires to the servo.
first wing sheeted and out, now for the second, then will work the innards, aileron, leading edge etc.
After checking it, it is as straight , and light as I knew it would
in these pictures , you can see the servo plate, and the landing block, , this time I am sheeting the underside first and the top next,
after preparing for second cut , I cut off the aileron, sanded smooth, sanded smooth also the wing leading edge , cut the proper thickness on my table saw from a solid balsa block the strips needed , then my buddy showed up so we ended up cutting the second side of the second wing,
