ericb
Team WTFO
I have extension that go up so I can unplug my batteries at the end of the day since it draws a little power in the off position. RX plugs right into the board.
crashflow
I wonder if it is big enough to handle the draw of a 40% with 9 servos? otherwise it would solve my lipo jittered servo problem. thanks
Guess what day it is............ MAIDEN DAY!!!!!!! Well fingers are a little rusty yet and first flight on a Viper since October so it took 3-4 minutes to get comfortable again. And we had this stupid persistent wind that was rolling over the trees and out of the gravel pit with lots of turbulence. But, that's to bad, the sun was shining and it was a good day.
Maiden was un-eventful but a blast. Couple clicks of elevator, one aileron and one rudder. Three more flights after maiden got the KE mixing done as well as flap mixing and cleaned up some expo and other things. Last flight today felt really locked in and good.
Note, when you watch the vid this is a DA100L Engine with a 27x9W Falcon prop. Vertical performance is astounding and quite addictive. It's literally like flying a foamy.
