Okay, but here's what I speculate is the crux. And, if I'm right I'm kinda mad at myself because this is what worried me when I first went to glue in the hinges. I looked at the job, then looked at the instruction manual, then said to myself, "really?". I then called Rocco for, and I quote, "some criteria" haha, on how to put these things together for a perfect result. You know, what are the determining factors? Anyway, what I saw was the slots were cut out into balsa, and that balsa is a soft wood and these were big slots. In my mind, no way could I just push all the hinges down into that slotted cavity and have all the hinge pins line up. Sure if they jig drilled into a more solid surface I could do that with a precision result... but not a big slot into soft balsa. It was Friday night at 8pm and for some reason Rocco didn't answer the phone. haha So, I just decided to do it like the manual showed. "It'll be fine" I said. haha Well, imo, do not do it like the manual. First off, unless you're really good, fast, and organized, you will not have enough time to get all 12 of those hinges in. Second, I think I have a better way.
I already talked about gluing the hinges in the ailerons first, letting them setup, then gluing them into the wings. That is fast and easy. All good, except I still had binding past 30 degrees of travel. Why? Maybe partly due to the hinge pins not being in a line, but I speculate mostly because of the slots in that balsa that I was concerned about from the start. I had an idea. And, I think if I had another set of wings it would be even more obvious. But, I grabbed an elevator half. I put the hinges in, and just as I suspected all along, they do not finish in a line. You see I tried to use a straight edge to get the pins in a line on the first aileron hinge gluing I did. But, because of the pocket you can't do that. The pocket is in a U or V shape and doesn't allow you to see the side of the hinge pins to line them all up. But.... but.... if you don't do it the way it shows in the manual (of gluing it all together at once)... and you glue the aileron first... then you can use a straight edge to line up the ends of the hinges. That will line up the hinge pins!!
If you hinge per the manual your hinge pins will not be lined up. Again, that was my initial fear and I'm mad at myself for not working it out before I started gluing. I never used to look at manuals, I'm getting old. haha
Here is a picture of the hinges pushed into the elevator... when the straight edge hits two of the hinges the others are all short of hitting the straight edge. Meaning the hinge pins do not line up. You know that ain't good!
