60" Laser-EXP
wedoitall
Member
Got my laser today!!!!!! Hopefully by the time I finish the build I'll get the last package (servos ) to finish it up.
bryanb
Posting this around to see if anyone has a spare wing tube that I could buy. I cracked mine today I checked EF's website and it is not listed as a replacement part - maybe because it is out-of-stock? My measurements indicate:
2 5/8" OD
22 7/8" Length (or 58.3 cm)
Anyone know the size or even if an EF 60 Laser / Extra would use the same tube?
2 5/8" OD
Bryan, and interest in a spare set of blue laser wings and SFGs to go with the wingtube?
I'm still selling my leftovers. :)
dth7
My bad. It's late and I thought you needed the sleeve from the fuse. Oops sorry.
dth7
2 5/8" OD
Bryan,
I woke up a bit more and this should make up for my messed up post(s) earlier. Try these guys-
http://www.funwithwind.com/store/ListCategoriesAndProducts2.asp?idCategory=181&idparent=171
I bought a stiffer wing tube for my Radian Pro form them.
Or these guys- http://www.jtecrc.com/carbonfiber.html
Good luck.
bryanb
[MENTION=382]wedoitall[/MENTION], no rush and THANKS!. I sent you a PM on the other forum. Let me know if you didn't get it. I am not in a huge rush.
[MENTION=769]dth7[/MENTION], thanks! I will check them out. I was worried about getting the exact dimensions because of the tight fit. I will probably still call EF to find out if they have the dimensions.
