Sport Cappy cuts/builds an old school Ultra Hots with a few mods.
capthis
You guys ever wake up in the middle of the night after realizing something? I had the worry my Elevators wouldn't allow enough rudder throw since I moved the hinge line forward etc. So at about midnight O'thirty I went out and checked. I have a lot of throw but I think I am gonna notch the corners of my elevators to get just a touch more throw.....
I then went back to bed without that panick feeling! :)
capthis
I got the wing on and lined up. I drilled and tapped the ply and poplar blocks for 1/4-20 and then hardened the threads with thin then retapped.
Once the glue dries for the front alignment pins then I can build the hatch and nose.
capthis
This morning I removed the wing and cut and glued in my landing gear blocks. I used a scrap piece of the tri stock to space them against the fuse sides and clamps to hold them down.
capthis
I really hate epoxy so I've been using tite bond. I've found you can mix some balsa sawdust with it to fill in places too....
While I was taking a picture I really like that Elmer's filler. I think it's glue and sawdust mixed together? It's a lot tougher stuff than regular light weight spackling and is nearly the color of balsa.
