just finished gluing on the skins. this was not easy. in all the threads on Dalton builds, no one discusses how to actually do this step. reason is not easy is you have limited time, and you want to make sure you get glue on all contact surfaces from the fuselage to the balsa skin, and, at same time, you want to keep weight down and not put too much glue in there.
what i did was, with the skin to the side of the fuselage, i used a brush and the Titebond, to apply glue all the way the length of the top most aspect of the skin, which is actually on the bottom, since the fuselage is upside down.
then, using the brush, i applied glue to the fuselage side on the stringers (2 sets, one high one low), and then on the formers and all major surfaces.
then i applied the skin to the fuselage, and placed the side presses. did the other side, placed the side press, then used rubber bands to hold things to gather. this was not optimal in tail and F1 area, so i also used a clamp and then there was full contact. then, i modified the brush, so that it was on the end of a screwdriver. now, i went over again all the surfaces on both sides, to assure there was glue everywhere. took a good 1 hour or so to do. anyone else have a different or easier technique to do this?
![1928=972-IMG_5884.jpg](http://giantscalenews.com/oldwpattachments/attachments/1928=972-IMG_5884.jpg)
![1928=971-IMG_5885.jpg](http://giantscalenews.com/oldwpattachments/attachments/1928=971-IMG_5885.jpg)
