Well Guys,
I went to the flying filed this morning hoping to get a little flying in, but it was a bit too windy. . .
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
However, all was not lost because I had my Laser with me and my camera. so I pulled the Laser out of the back of the Durango and put it together. It went together easily except the dowel on the front of the right wing panel was a bit too tight. It appears that it does not quite line up with the reinforced hole in the side of the fuse. That's no biggie, it is not off by much so a little careful work with a round wood file and it will OK. Each wing half is bolted to the fuse with two 1/4-20 steel wing bolts. Anyway, I took some pictures to post here, then I took the plane back apart and came home. When I got home I figured I'd go ahead and take the servo's out of the plane so I did that. Then I brought my camera inside to download my pics only to realize that my cable I use to plug he camera into my laptop and download pictures was not in the camera bag. I realized I must have left the cable at the office the last time I used the camera for work. My mom always used to tell me that I would leave my head somewhere, if it wasn't permanently attached . . . . .
While I'm typing, I might as well tell you Guy's that I have changed my mind again for the last time (I think). . . . .
![O O :oblong: :oblong:](/styles/default/xenforo/smilies/O_o.png)
My 55CS is going in the Laser and I'm going to save the twin for my AMR Stick. It will be allot less work for me on the Laser and the twin is better suited for the Stick because it REALLY needs the extra nose weight.
I will be busy tomorrow night so pics are going to have to wait until Tuesday evening. Sorry . . .
