I am not a fan of expo I run 15% on all my stuff. I find most people are using way to much and when they get in to the slow Alfa stuff it fells like mosh and are way behind it. If you can set up a DR switch just to change expo keep the travil the same and switch expo while flying to what you like then it is easier to fin tune it
+1000!!!!!!!!! I taught myself to fly two years before I ever joined a club or really saw anybody else fly in person, and never used expo on anything and never used rates on anything. When I started in 3D I added a little expo because the planes got more capable but I still rarely use dual rates. I set up rates just because I buddy box lots of people on my planes but that's the only time I use them. I got second place last year in IMAC with a plane set up for 3D and I flew high rates the entire time.
You just have to find the correct mix that works for you and don't be afraid of the plane, especially if you have the ponies on the nose to get you out of trouble.
@49dimes what I did when I was struggling with rollers was this:
Set the ailerons on their own dual rate switch and practice rollers with low rate ailerons (since they are pegged anyway) and high stabs and rudder. Eventually I just kinda started being able to fluctuate the aileron stick without thinking about it. Also, if you are like our friend
@aarestor that looks like he's getting lost with his rudder you can also do rollers with no rudder input.....just get used to moving one stick at the right time first. They don't look that great but it is good training. Then you'll also find out that it takes VERY little rudder to clean up your rollers.
Last thing I learned with rollers is too pick a direction to push your stick with a little more emphasis to steer them. For me its down elevator (forward sick) and I push when I see the belly of the plane coming in order to steer the plane straight or around corners and loops. This is how I started anyway.
