3D Viper build log (maybe)
Well just got back from JoeNull and started un packing the kit. Man does it look good. Happy with all the parts. The lazier cutting is clean it will glue great with out any sanding or work. Looked at the couwl it looks great and split with sides that really cuts back on a lot of work splitting a cowl.
Be watching your build to help me do mine this coming winter.
daman691003
Start of the press. Making it with casters. Wood dimensions bottom is 14x14" middle piece is 14x13". I used a good grade 3/4" plywood.
daman691003
Manifold assembled. Very easy per instructions.
Pump arrived and mounted on carrier. Not sure if I should use bushings.
daman691003
One side down. Took three hours. Came out goodish. Iam getting better and better at covering. Learning little tricks. Getting closer to starting viper.
