Well, here we go then. I got some time today to cut a couple of fuselages and some partial fuselages to do some testing for carbon longerons vs spruce longerons. I'm also cutting from light ply that I have previously not used so I want to double check that for consistency and strength of materials. I got some super good quality poplar light ply that is clear on one side (no knots) and 95% clear on the second side. I also got some super good 3-ply Baltic birch that is very strong. It also cuts very clean.
So far the lite ply is the cleanest cutting I've ever cut and comparing weights on the birch of cut parts it is very slightly heavier but bending strength is stronger than the birch I've used previously. Not all parts, but here are a few shots of the parts cutting.
Also the spruce 1/4" sticks I got from National Balsa are not cut on a high precision saw so they are a few thousandths off. I am lasering parts to more accuracy than a few thousandths so what I will end up doing is supplying longeron material with the laser parts. Again, this is if the kit part of this all comes together. I can sand 30-40 sticks at a time with much more accuracy than their saw so it will work better for the kit builder.
So for creating longerons: They must be scarf-jointed for strength. There are a couple ways to make a scarf joint but I prefer the disk sander. If you don't have a disk sander you can simply clamp a block over the sticks at an angle and use a razor saw to cut them. Finish with a sanding block for a perfect fit if needed. Test fit by holding the sticks against a known straight edge like an aluminum angle. I like to glue with wood glue, let dry and chase with thin CA. Then sand with a block to smooth the joint completely. Joints should be .75-1" wide and tightly closed as shown. If there is a gap, sand further before gluing!
19833=12792-image011.JPG]
