Bdegan;20248 wrote:
I'm back at work now. But I just realized that stand off length needs to be considered for you to get a proper length fit.
because F1 to the back of the spinner might be different on you viper than this 330.
I didn't measure exactly. But my standoff is 1.75 inch plus the length of the DA70
Yes, I'd need more technical specs but just for a rough idea I figured this info would let me to a two second sketch. Looks like it may fit but header drop may be tricky and the pipes need to go up at a 1.5* angle from F-1 back in order to clear the belly pan. Radius of the pipes looks like fit would not be an issue. My landing gear is recessed and canted forward a couple degrees, I would have to modify that plate for you as well, but that's only a couple minute cad mod and send them to the laser. Looks like that's the only part needed to be changed. I could also move the engine box out to fit your engine without a huge spacer, with this engine box it only requires a .5" spacer for a DLE120 or a .75+/- spacer fora DA100 so you are only looking at a 1.25" spacer for a DA70.
We are a while out on kits if indeed it comes together so we could discuss via E-mail and maybe get something worked out depending on your header options.
