Drew
Motor installed. Gary went with the Motor-Fly motor which is a bigger "X" mount then what the kit recommends therefor needing to create new firewall holes and opening the front cowl hole bigger.
Marked the new hole locations and removed the blind nuts. Also filled the old holes with wood dowel rod.
Installed old blind nuts and hardware included in the kit. Had to open the cowl hole little over 1/8" all around to clear the "X" mount and to clear the drill bit for new holes.
