Well, didn't get much done this weekend on the Beast since I have been sick with a wonderful stomach bug.:cursing: Anyways, here is what Ive done....
Got the elevators installed, nothing special here, just epoxy in the wing joiner till dry, then CA the hinges like we did the rest.
Next you need to set up the tail wheel assembly.
Use a file or dremel and make your flat spots on the rod for the wheel collars to keep from sliding off. I also use the red thread locker for the collar screws. Never have had one come off.
Then add a little epoxy to the rod where it will meet with the hole and wood surface. I went ahead and used the epoxy to glue in the elevator and rudder control horns at this time.
Last thing I did tonight was start getting the tail servos ready for install. I like to use heat shrink for the connections to keep them from coming off.
