Alky6
Finally getting to the MOJO 65 build. Had the short kit sitting for a couple years now. Had to finish the JTEC first. Will be using the VVRC 20cc for power. Unfortunately, the designer (Paul Swany) has closed up shop and his website is no longer up.
I do have the .dwg file and a zip file with the manual, two full size .pdf's of the fuse and wings, and a cut sheet with the parts all laid out on different sizes of lumber. I plotted all of them. The plans can be found on the PROBRO site under the thread title Mojo 65 last run. Everything is there if someone wants to scratch one out.
I laid all my short kit parts on top of the lumber layouts. There are some differences from the short kit, but the zip layouts seem to be consistent with the plans. One notable change in the layouts is the fuse is already sized for a 2occ power plant. The original short kit that I have is setup for an OS120, a bit narrower in the fuse cutout for the engine. That (enlarging the opening in the fuse for the 20cc) will be the first order of business before moving forward.
