Looks Badazz!
One thing I have found is painting the tunnel and engine box helps dampen the sound. Are you sure those are Airman wheels? They look a lot like the limited edition Whiterose and the axels look like Whiterose also.
Consider yourself on report. To the corner with you.I read between the lines and see two things. ST and Purple! Luv what you have done Rob but punish me and tell me to go stand in the corner where AWESOME is!
Now that you mention, you're more than likely correct. If memory serves, Airman stamps their name in the side of the wheel...right? As I remember, the Hemple had Airmans. They were stamped. These wheels are not stamped. So you could be correct. Now you have me curious.Looks Badazz!
That means a lot to me. Thank you!Either way it looks awesome! you have done a fantastic job and this coming from someone who knows the hours and hard work that goes into something like this.![]()
@49dimes you may come out of the corner now if you promise to play nice.
