Would using an Equalizer II or two free up some channels? I haven't tried one but thought about it a few times.
I didn't make the connection on the dx8 limitation.
You "could" use one channel for each wing, and split out the power wires like was suggested earlier. By ensuring each servo has its own source of power, no reason each wing couldn't share a "signal" wire. The powersafe 9 channel ar9110 would allow for this.
I have read that you can mix with flaps on a dx8 and run 4 aileron servos. So if you were in my position would you just share signal wires or go with another receiver and a power expander?
If I were in your position, i would buy a dx9 and sell the dx8 in classifieds. You'll get most of your money back and it solves the problem for future as well as this airplane.
If above not possible, then id share servo signal wires. Setup here is critical however, so patience and servo tester would help greatly.
If I buy a new radio I will just bite the bullet and get a dx18. I'm in no big hurry to build this plane I have been waiting all summer for the air frame. I thought I would just build it over the winter and buy a little at a time. Here is my plan for equipment.
Da 120
32oz fourtitude tank
Hitec 7955 alieron,elevator
Hitec 7950 rudder push pull
Power safe rx running 2s lipo
Power box ignition cutoff
What do you think?
Have you tried any of the servo arms that taildragger sells?
Da 120
What do you think?
Just get a Matchbox, that will solve your problem.
