3DHS 58" Edge 540
SnowDog
nice work on the jigsaw puzzle!
FYI, the vent in the bottom of the fuse is important - it allows an exit for cooling airflow over the motor.
If you don't have it, the motor will possibly overheat.
Don't know who the previous owner was, but I respectfully disagree with his opinion.
wedoitall
Member
Getting there! I didn't have any thick CA, so the glue was running all over the place...
I reconstructed the motor box in my wattaplane slick. mine may have been just lil worse off than yours. mine had the crack going across the front where the motor mounts up, just like yours. I ended up using some flat CF to give extra reinforcement. I have about 100 flights on the repaired motor box.
njswede
100 flights? Didn't you get that plane pretty recently? You must have a life outside of work and kids. How does that feel? :)
Thanks Josh for the fuse! She arrived perfectly unharmed thanks to your expert packing!
Now I've got some surgery to do on my old tail...
