Nice job, Gary. Can you get a weight measurement before putting it at risk again?![]()
I suppose I should probably buy a fish scale or something to get a weight on at the field
Assuming you're using spektrum telemetry for in flight rpm.. Care to share your setup? I've seen a lot of concern over ensuring you don't have connections that will render the optokill or I bec useless because of creating path from ignition to rx.
I don't know what gary's weight is but my 92" edge with gp 61 and smooth pipe came out to 17.22 lbs or 7813g
[video=youtube;XmTbi06hVes]http://www.youtube.com/watch?v=XmTbi06hVes[/video]
Gary, to tune out the mid range burble I usually richen the high needle a little so I can lean the bottom needle. When the idle becomes unreliable then you have gone too far!
My build thread on this beast can be found here....just got her flying this week before a big snow storm:banana::banana::banana:
oops never mind, rccanada is off line right now!
lorne
