After getting several flights on the bird it needed a good inspection so I spent this evening going through everything. Started on the exterior and found that there was a piece of covering pulling loose from the bottom abutting the cowl. No big deal, brushed a little Sigs on it and ironed it back down and while at it might as well go over every seam, joint, and end lap. All bolts, fasteners, couplings, tape, and straps were secure so I moved on to electronics. The batteries took just short of 1600mah combined to recharge, not bad for about 32 minutes of airtime. Having two 3400mah batteries and only timing for 60% drain that gives me just under 2 hours of flight before even considering recharging. Checked all the wiring to ensure there was no chaffing to tend to, hooked the meter in line and cycled the servos, all was great. I also gave the engine compartment a good looking over, there was no sign of exhaust leakage or spitting from the carb.
I also went ahead and ordered some more vinyl from B&E, but going to wait on Mike for the main fin/rudder one.
