Hopefully you can return those for a full refund.
@WMcNabb,Oh No! I had the same problem with my DA100, and thought for sure it would fit your 3W.
No worries. I’ll take it back.
Dang it Kelly,
Here I am getting ready to got to bed you post that picture. That's not something anyone should see right before bedtime. . . . . . .![]()
That is just painful. That should not be allowed to walk the streets.
.You would. . . . .Yea...I liked the string bikini much better anyway.
was just shopping for a switch myself and there are a lot of threads out there about Miracle Switches that have failed and caused crashes.
Back to the old faithful MPI switches for me
http://www.maxxprod.com/mpi/mpi-4.html
.Tanks @Bartman,
Now that you mention it, I remember reading about problems with the Miracle switches as well. Unflortunately, the MPI switch with charge jacks are only rated for 6.0 volts and it is not large enough to fill the hole in the fuselage. I'd also like to find a double switch / charging jacks if I can since I'm lazy. . . . ..
It is bad enough that my flying wrecks a lot of my airplanes!
Tanks @Bartman,
