to do list:
1. cover the stabs/elevators
2. obtain wings (coming in next week) and cut out ailerons (as per plans), glue in LE/TE, and LE/TE of hinge line. glue on caps on tips and roots. lots of planing, lots of sanding. glue in the servo boxes (2 per wing). glue in hard points (2 per aileron).
3. once wings are done, i can cover the fuselage.
4. i still have to finish the canopy. i need to finish the instrument panel. the pilot is finished, i just have to prepare some form of anchoring device. the canopy needs doe fine sanding, then covering the canopy area that should not be painted. need to find out which would be best masking tape for this. i believe also called trim tape. then, primer this, several coats then fine sanding. then pain top of canopy/hatch red. (to match the red from Monokote).
looks like i am far from finish, but much closer than when i started october 7, 2013.
